ARD Green impression and review
trophytaker308
- Year and Model: 1995 850t turbo
Re: ARD Green impression and review
cant wait to see your track times.have fun.
1995 850t turbo,siver with black leahter interior (perfect),, 118000 miles .second owner.9 out of a 10...!
If you're having trouble with power below 1500 rpm, that's likely not turbo related as few turbos (even in the TD04 range) will be making much boost at this RPM. I'd look more to cam timing and perhaps a bit of overlap may be to blame...
I recall your mechanic set your cams for you, is that right? Might have him double check the settings and confirm what they indeed were set to....
Keep me posted and I'll help anyway I can!
-Lucky
-Lucky
s70glt novice[Will]
- Year and Model: s70 glt 98
I know its not turbo related, It happened, or at least i noticed it, after the tune. It's not bad enough to change it. It might have been belt slip (ahhhh scary!) And Lucky, you've done enough and have your hands full finding new ways to be awesome.ARD-Lucky wrote:If you're having trouble with power below 1500 rpm, that's likely not turbo related as few turbos (even in the TD04 range) will be making much boost at this RPM. I'd look more to cam timing and perhaps a bit of overlap may be to blame...
-Lucky
Also, wastegate adjustment nut is frozen on, and im out of PB Blaster. I also enjoy tires and grip, so no new video. Sorry
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
- 35 Replies
- 6747 Views
Last post by erikv11
- 1798 Views
Last post by bmdubya1198
