1999 S80 T-6 P0303 Error even after changing parts
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Re: 1999 S80 T-6 P0303 Error even after changing parts
Post by chrism »
Hopefully it hasn't dropped a valve and locked up. Before going any farther, and risk serious damage, you may want to put a socket on the damper pulley bolt and see if you can turn the crank in both directions.
diamond963
Year and Model: 1999 S80
Post by diamond963 »
I will do that tonight or tomorrow morning.. thanks for the heads up.. literally.. :)
diamond963
Hey Chris, I am havinbg an issue getting my habnd down close enough to the bolt to get my socket on it.. I am thinking reaching it from under neath, but would like some guidance if you or anybody has any. I can not get my hand down the left side. there seems to be minor clearance between the engine and the wall.. argh!!! frustrated.. thanks for any help
diamond963
OK an update, I just pulled the starter out of the car and bench tested it and it passed with flying colors. I was able to hook up a battery to it and the solenoid engaged and the wheel popped out and spun at a high rate of speed.. sound like something in the engine.. need to try to manually turn it over.. any other ideas.. thanks
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
might still be a starter issue, but yes, next step is to turn the motor over by hand. Pull the spark plugs to make it a little easier to be smooth in doing so.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
