Best/cheapest place for a new radiator? 96 855R
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Re: Best/cheapest place for a new radiator? 96 855R
Post by vjaneczko »
One other thing to keep in mind is the two mounting bolts that hold the rad onto the frame. Soak 'em with PB Blaster at least overnight - if not longer! I had one come off easy but the other was rusted tight and I spun the bolt off of the frame, leaving a hole in the frame where the bolt was mounted. I had to run to Home Depot and fashion together a fix.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
thecheat
Year and Model: 1996 850 Turbo Wagon
Post by thecheat »
I bought a radiator from RockAuto and it is identical to the radiator I removed except the oil and trans couplers were separate brass fittings that I had to screw on myself.
Here is the info on it:
PRO 8012099 Radiator $ 118.79
PRO is the brand, I guess they're some kind of OE cloning company. My upper oil hose is leaking but I never replaced the o-rings and that is likely the problem, not the radiator itself.
