2000 S70 N/A Timing Belt Replacement Problem(s)
tridents65
- Year and Model: 1995 850, 2006 S-804
I'm in the middle of replacing my timing belt this week end. Thanks from all of us Lee. Your help and instructions are most appreciated! I was not sure about if I have a VVT or not (I have an '06 S80 w/ turbo) but by your discription I will reset my timing marks as I had set them only rotating counterclockwise. I will do it clockwise and past 90 degrees as you say then back to the marks. Now if I can just figure an easy way to get the timing bely off from behind the crankshaft pulley.
1965 Chevy C-10
1954 Chevy BelAir
1949 Plymouth P-18
1995 Volvo 850
2006 Volvo S80
2004 Grand Prix
1954 Chevy BelAir
1949 Plymouth P-18
1995 Volvo 850
2006 Volvo S80
2004 Grand Prix
longpr1957
- Year and Model: 2000 volvo s70
my car jump timeing and bent all 10 intack valves i replace all ten ii set timeing by the back of the cams and again by the marks on the cams and crank al it will do is spend over not even trying to start i have reset timeing 4 times still the same can you help fine out what is going on here thank you so much for your time
- 5468 Views
Last post by jimmy57
- 23 Replies
- 17972 Views
Last post by jonesg
- 20 Replies
- 17739 Views
Last post by Hurtfeelings
- 18 Replies
- 2169 Views
Last post by dikidera
- 1080 Views
Last post by rspi
