Who has turned rotors?
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Re: Who has turned rotors?
Post by regent »
MIJ,
Did you perform a regular bedding in?
Thanks
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I had not- after hearing the squealing I just came on home...
I should do that- I have done 4 drives pushing it to 40 or 50 mph and then slamming on the brakes and almost coming to a stop...letting the brakes cool and then doing it again. What have you used?
EstVolvo
Year and Model: 2000 V70
Post by EstVolvo »
I have noticed that squealing depends on weather and humidity.
Now, hard braking causes the ABS to engage.
Does anyone know what causes this?
Should I rebuild the calipers with a caliper kit?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Clean the ABS sensors and reluctance rings on the axles with an old toothbrush and some solvent - carb cleaner, Simple Green, etc work well. Hopefully that helps.
'98 S70 T5
2016 Chevy Cruze Premier
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
MadeInJapan wrote:So it has always been my take to never turn Volvo rotors- I've replaced pad sets after pad sets without doing this without any issues. However, my son's 850's front breaks squeal badly when coming to a stop.
I always take the rotors for resurface job when it comes the time for brake pad replacing.Usually you can replace 2 sets of brake pads to one set of rotors.After that,rotors are at least out of spec or at at discard thickness.Here in Europe...every shop is doing resurface of the rotors when changing brake pads,exactly because of too many customer complaints about squealing brakes after replacing the pads.
I was also experiencing that squeal back in 2000 when i bought my car.I replaced brake pads without resurfacing the rotors and the noise during braking was like the train is comming to a stop.I took the car to a "brake" shop,they resurfaced my rotors,said that i need to be carefull during "bedding-in" period(to not overheat the brakes in first 300-500km) and i never had that squeal again.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
The thing is I resurfaced both rotors and pads so that is not the issue...I will try cleaning the sensor. Otherwise, I have an issue with the calipers I think...but they are not sticking.
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I used some goop from Permetex called Disc Brake Quiet on my son's car. He had meat on the pads but I have no idea what brand they were. It did work.
It is almost like RTV, it dries to a flexible solid.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
MadeInJapan wrote:The thing is I resurfaced both rotors and pads so that is not the issue...I will try cleaning the sensor. Otherwise, I have an issue with the calipers I think...but they are not sticking.
There is no such thing as resurfacing the pads. It is neither an industry practice nor done by any mechanic who has a legitamate business. Your liability insurance carrier will drop you like a hot potato as soon as the first customer crashes his car and blame you for resurfacing the pads :lol:. You can never get the pads to be even all the way around so it mates flat to the rotor surface especially after thousands of miles of use. The squeak could be from the air gap in the mating surface as you let off pressure after coming to a stop. Try greasing the Caliper guides if it does not work a set of Organic O'Reilly pads should cure the problem as they are soft but still work well though they may not last as long as OE's.
regent wrote:MIJ,
Thanks
Bedding In is only good for new Rotors and Pads. When two pieces of glass are flat against each other there is a lot of friction. You would not want the pads and rotor to be glass like or the brakes will grab but during the Seating process the pads and rotors are being made flatter and smoother very quickly depending on your method. Resurfacing the pads will leave you with so much gap here, there everywhere you could not Seat It or worse case scenario create hot spots on the Rotor causing grippy braking or warp rotor.
MoVolvos
Post by MoVolvos »
+1 on always having the rotors turned as it is Standard Practice but there are many cars that you can get away with a "Pad Slap" and never experience squeal. So far so good with the Pad Slap with the O'Reilly Organic Rear Pads for my T5.
_
