For loan: Delta link bushing tool (P/N 9995497) - NEW THREAD
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Ok. I'll contact Xpletive and take over. Thanks very much.
If/when you want to end this arrangement and get your DLT back for good, that's your call. :-) I'll make your account "MVS Contributor" status to reflect your trust and generosity.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Oh, and if the tools vanishes, I'll PayPal you $130.
Also -> Amazon link
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
matthew1 wrote:Ok. I'll contact Xpletive and take over. Thanks very much.
I doubt I will ever need it back "for good". I will use the loaner program to use it at some point, though...seeing as I didn't replace the fiance's Delta Links yet :lol:
Well, Xpletive already paid me. PM on the way - don't need a more complicated thread.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
matthew1
Site Admin
Post by matthew1 »
D'oh! PM received. Just to let everyone know I did understand that you don't own the tool any longer...
I'll offer to buy the tool from Xpletive. The few dollars that accrue (my "profit") I'll set aside for the DLTCO program... repurchase tool if it vanishes, cover shipping snafus etc..
Also -> Amazon link
Xpletive
Year and Model: V70 1999, 850 1997
Post by Xpletive »
My v70 is finally on the ground after being on the lift for an entire month!
The rear trailing arm bushings/links were a BREEZE with the tool - matthew i'll email you so we can coordinate getting the tool back in circulation.
matthew1
Site Admin
Post by matthew1 »
I have the tool, thanks X.
Tool Sharing page is up, https://www.matthewsvolvosite.com/mvs-to ... ng-program and the delta link tool is available.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
FYI, this Delta Link Tool program is humming along nicely. The tool is currently in Maryland, in the hands of its third borrower. ETA for availability is one week from today.
Everyone so far has been a good tool caretaker and good at communication, letting me know that they received it, how long they expect to have it, and when they shipped it.
Also -> Amazon link
mtd240
Post by mtd240 »
I just used the rental tool to replace the end links - ~3-4 hours total. Could have easily been done in 2.5 if I have to do it again.
1. Jack, jackstands, remove wheel
2. Remove splined bolt (18mm socket, BFH)
3. Remove lower shock nut (18 mm).
4. Remove brake line bolt on delta link (10mm, drivers side only)
5. Remove parking brake screw from end link bracket (T27)
6. Remove End Link bolt (18 mm)
7. Remove 3 End Link bracket bolts (17 mm)
8. Push bracket out of the way (be wary of hard brake line (drivers side) and fuel filter/lines (passenger))
9. Use a prybar to pull the end link off of the chassis
10. Jack under the shock (nut already removed in step 3). Jack up delta link until shock can be pushed off of the stud. Lower the jack back down until the tool can be fit over the end link.
11. Use the tool to remove end link (rather intuitive..)
12. Install new end link with tool (I put the "goalposts" at the black plastic part, not at the far end, when I pressed it in. You will know what I mean when you see it)
13. Reinstall all. Torque values are here --> https://www.matthewsvolvosite.com/forums ... f=1&t=9402(along with better instructions :))
Gone:
matthew1
Site Admin
Post by matthew1 »
This hot little tool is back in my grubby mitts. Holler if you need it.
Also -> Amazon link
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
matthew1 wrote:This hot little tool is back in my grubby mitts. Holler if you need it.
The tool "available meter" is missing from the QUICK NAV?
