I've been hoping for a good walkthrough on this job, and lo and behold Matt comes up with an astounding one. Thanks for the superb work!
I have a RMS leak, and I've had the parts for this for well over a year. Even built an engine support and a transmission cradle to fit on my floor jack. Seeing this write-up is sobering, though, and I'm starting to think maybe the leak isn't all THAT bad.
Volvo 850 Transmission Replacement Tutorial
1995 Volvo 850 Transmission replacement
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
I hear ya. Just took it for 400 mile round trip no oil that I can find thank god! It's nice to not have that RMS leak anymore. I do have a jerry rigged setup that takes crankcase pressure from my dipstick tube and routes it under the car - now that I know the leak is gone I can work on routing that into the intake manifold or try what someone else suggested and use bigger tubing into the PCV system (posted recently). Just a good feeling!whoa wrote:I've been hoping for a good walkthrough on this job, and lo and behold Matt comes up with an astounding one. Thanks for the superb work!
wheelsup, it's funny - I've been looking around for a DIY on how to replace a trans (I just got a 95 GLT that needs a new trans soon) and found this post - and I too live in Raleigh!
Thank you for the guide!
Barnett
- Year and Model: 1997 850 GLT Wagon
Hey wheelsup!
I just joined to thank you for this write up!!! I am going to undertake this with an 850 wagon. I just purchased it and then it developed a pretty good RMS leak. Thanks for a great very detailed write up!
97' 850 GLT Wagon, 275000kms
wheelsup
- Year and Model:
You're welcome!Barnett wrote:Hey wheelsup!
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
I know it's been a few years but I'm wondering if you recall disconnecting the evap hose, the one that runs from the canister down along the front of the subframe, then behind the front engine mount and between subframe and sway bar. Do you happen to remember if it gets disconnected at the canister or behind the swaybar? I don't want to yank on it at the wrong spot!
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
Does anyone know if the clutch fork can be removed without separating the engine and tranny. Anyone got a picture of the part itself? I can't seem to find one online.
Thanks
Thanks
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
Thanks so much for the insight and convincing evidence that the damaged flywheel will likely remain in the car as I'm reluctant to bring it to a shop for seven hours of work (over $1,000) and $400 for a new flywheel doesn't make too much sense for my 30 year old 850 turbo wagon. Still, knowing how it should be done is really helpful to confirm that the shop did it right.
If only I had a garage to take the car apart, tools more than I can afford (although I did buy a 30mm socket and 1/2" socket wrench to move the crank 5' to the next set of teeth), and days to commit to the task.
Great wrote up!
Gary D, NYC
Great wrote up!
Gary D, NYC
I’m in port Jeff area if you get motivated to pull the engine. I’ve got an engine puller
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
850, Turbo, Wagon, and Manual aren't words that go together very often in the States. Unless the car has lots of salt worm rot, it likely deserves another chance. Dr. Abscate would be a fine fellow to get to know.lrwagon96 wrote: 27 Jun 2025, 15:51 Thanks so much for the insight and convincing evidence that the damaged flywheel will likely remain in the car as I'm reluctant to bring it to a shop for seven hours of work (over $1,000) and $400 for a new flywheel doesn't make too much sense for my 30 year old 850 turbo wagon. Still, knowing how it should be done is really helpful to confirm that the shop did it right.
Great wrote up!
Gary D, NYC
- 3695 Views
Last post by arfstrom
- 14 Replies
- 7117 Views
Last post by SuperHerman
- 1697 Views
Last post by Jonboy74
- 1015 Views
Last post by JimBee
- 14 Replies
- 2518 Views
Last post by JimBee
