Knee bolster under glove box - 99 S70
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Re: Knee bolster under glove box - 99 S70
Post by stephansvolvo »
LOL.
Thanks
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
beigg
Year and Model: 850 97
Post by beigg »
Pics of this storage compartment?
ugh smh 850 Turbo fridge
stephansvolvo
Here you go
Stephan
98 S70 GLT
73 IH Scout ii
beigg
Post by beigg »
I want that!
Thanks for the pic Stephan
stephansvolvo
beigg wrote:I want that!
I pulled this out of 2000 V70. Based on what I've read the bolsters were removed after 99. Small little upgrade but great for the little stuff. It's pretty deep too.
Stephan
98 S70 GLT
73 IH Scout ii
beigg
Post by beigg »
now I have something to look for to "enhance" the ole rolling brick.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
stephansvolvo wrote:
Here you go
This is an old topic, but I recently did this repair/upgrade:
Swapping a '99-00' cubby hole panel into a 98.
It is almost a direct swap; first, the knee bolster needs to be removed (perm delete) . Next, if you try to attach your donor panel into your 98, the top mounting stud for the bolster, (top right stud, when sitting in passengers seat, used ) gets in the way of your new cubby shelf. How I solved this problem is to take a dremel tool and cut out enough plastic from the new cubby hole panel to make it fit. (i thought about cutting stud off but it might still be to short) It is possible but takes some patience. Worth the upgrade. pictures to follow
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
[email protected]
Year and Model: 1999 S70 GLT
Has thanked: 3 times
Post by [email protected] »
Just bought this 99 S70 and replaced the heater core. Sitting in the car now trying to see if it works and doesn't leak. No knee bolster here either. Thanks for the words of wisdom.
Papa G 8)
Has thanked: 1836 times
Been thanked: 1709 times
You don't have the metal knee bolster in the 99-00 cars, but you should have a hard foam insert below the steering wheel above your knees.
Has thanked: 1497 times
Been thanked: 3810 times
There's quite a difference in safety stuff between EU and US markets.
On SWMBOs BMW, the EU model get a hard dash with lots of cool cubbies because the Germans think if you don't wear your belt you deserve to get banged up on a hard dash. Here we have to coddle to the world beaters who think seat belts give them gas so we get big pillow dashes and lose all the cool storage stashed.
