I had included the photos measuring the seals just to drive home the point about the seals being different sizes. But from the sound of things it seemed as though it was a direct swap type of deal, one seal out, one seal in, then you can use the FWD axle with no need for the bevel gear collar to keep it from leaking.
That is apparently either not the case, or I am missing something (such as maybe I am supposed to remove the hollow splines short shaft that mates with the bevel gear collar then the seal fits deeper in the trans ?) Because as shown above, the seals are different ODs and even if that weren't the case, the seal wouldn't do too much if the sealing surface happens to be a splined shaft...
jimmy57 wrote: ↑18 Feb 2013, 17:59 Or you replace the existing RH trans seal where collar inserts with the seal for FWD car and a RH front axle. The OD of the trans where seal fits is the same AWD or FWD. The ID is either for angle gear sleeve or on FWD it is a smaller ID for axle. AWD RH axle is not finished for seal in the right place so a FWD RH axle will need to be used. When you run with AG removed and collar fitted you have to concoct a way to keep sleeve in place and the RH axle will rust and never be useable for a convert back to AWD.
Jimmy57, there is the axle seal inside the splines shaft that engages with the spline of the collar, as pictured above. In your scenario, what is done about this component? Also, the OD where the seal fits as you mentioned, actually appears to NOT be the same AWD and FWD...
Unless perhaps I have the wrong trans..? Where can I check for a number to identify the model of trans I have is in fact an AW50-42LE?
