If they did, it would leak, no?JDS60R wrote:After rechecking the fluid level make sure that neither of the axles popped out.
Problem after transmission fluid change
Francois850
- Year and Model: 97 850 Non Turbo
JDS60R
- Been thanked: 3 times
No, many times they just pop out a little and do not leak - just enough to cause an issue that's hard to find.Francois850 wrote:If they did, it would leak, no?JDS60R wrote:After rechecking the fluid level make sure that neither of the axles popped out.
Retired
Francois850
Do you think that would create the problem that badly if it's let's say 1/2 or 1 quart too low?JDS60R wrote:answered above - lower of the two readings as dipstick enters at steep angle
Francois850
Ok will check and see if I can notice anything wrong... thanks!JDS60R wrote:No, many times they just pop out a little and do not leak - just enough to cause an issue that's hard to find.Francois850 wrote:If they did, it would leak, no?JDS60R wrote:After rechecking the fluid level make sure that neither of the axles popped out.
JDS60R
Only focusing on things that matter. I won't ask you to check the gas cap or the radio.
Where is the dipstick level of the fluid when car is running and in park? Are you checking the top or bottom of the stick?
Retired
Francois850
I am not sure I understand this question.... I truly appreciate your help but I don't get it.JDS60R wrote:Only focusing on things that matter. I won't ask you to check the gas cap or the radio.
JDS60R
I need the answer to this question to move forward with helping you.
Retired
Francois850
I think I got it now, when hot, if I take the fluid level (lowest of the two sides) when the engine is hot and running in P then it's probaly where the cold marking is... makes sense?
JDS60R
Yes - It sounds like you are a little low on fluid as you reported you are getting the cold range indicated when the fluid is hot.
Please add some fluid so that it is in the hot range when hot.
Retired
- 16 Replies
- 3755 Views
Last post by fourteen2hands
- 1317 Views
Last post by robrike
- 19 Replies
- 5140 Views
Last post by erikv11
- 3451 Views
Last post by oragex
- 2886 Views
