ABS wheel sensor?
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
oragex wrote: 10 Feb 2019, 10:28 Interesting. Is the wire correctly attached to the strut plastic (or metal) bracket?
Speaking of these sensors, careful not to pull on the wire (even just slightly) when removing a sensor or working on the suspension, always pry out the sensor with a flat screwdriver from underneath.
Yes the wire grommet was properly seated in plastic holder. I had finished working in the dark, I use work lights but shadows cast a different view sometimes. Anyway I had leaned on the brake dust shield so much that it was squeaking horribly first day of driving after repairs. That's the only thing I could see that could have caused this issue. I was replacing brake pads, brake rotors and brake fluid soft lines. Maybe when I hung the caliper on the bottom coil spring winding I possibly crushed it. I spliced back together and seems to be working fine now but I ordered a new factory sensor from FCPEURO.COM just in case I need in near future.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Has thanked: 1611 times
Been thanked: 4075 times
I spliced my back one about 6 times before I broke down and bought a new one from FCP
Those wires just don’t solder well and are awfully small to crimp.
