Still no spark=Pearl is parts!
quahog pearl
- Year and Model: 1995GLT850,2003S60
BTW, tranny never separated by me, DEFINITELY not by previous owner.
mercuric
- Year and Model: 1997 850 T5
- Been thanked: 2 times
2-1-4 is for the crank sensor, 3-1-4 is for the cam sensor.
28: 2-1-4 RPM sensor signal, sporadic. Signal faulty
DTC information2-1-4
If the ECM counts more than two teeth too few or too many on the connecting flange/flywheel for two consecutive crankshaft revolutions, DTC 2-1-4 is set.
28: 3-1-4 Camshaft Position (CMP) sensor signal. Signal faulty. Intermittent fault
DTC information3-1-4
If the ECM does not receive any signal from the CMP sensor for 2.4 engine revolutions, DTC 3-1-4 is set at the next attempt to start the engine.
Everyone, right now, put down your keyboard, and go check your grounds..or earths as appropriate...
quahog pearl
Well, better late than never, but SUCCESS!!! Replacing the crank sensor did the trick. Stupid me, I checked the resistance of the sensor and it being about 280 ohms, I figured it was probably OK and I moved on to looking at other things. The new CKS (a cheapo) measured 304 ohms, but of course, there must have been a difference in the efficacy of the shielding or something.
I did tell my wife that I would put it up for sale, but first her son wants to learn to drive a stick, so Pearl will be around for a little while longer. The car runs so well and is fun to drive, but my herd is too large
Thanks to Jimmy and others which led me back to a more logical path!
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I recall both reading and being told that the manual V70's could not be push started. I forget the rationale -- perhaps anti-theft. What I can say is that I have attempted to push start mine without success before I was told it couldn't be done.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
quahog pearl
Well, my 850 can be pushstarted quite easily. In fact, it can be done in reverse!
One thing I learned on my V70 the hard way...don't let anyone use those big pack starter boosters to give you a jump start.
The hand carry able ones are fine.
SWMBO got a jump at the bus depot on a weak battery, and the next day 2 coils went bad, leaving us in downtown city at 2330 hours in -20 F weather......
- 1788 Views
- 1113 Views
- 1779 Views
Last post by Pacoddog
- 2235 Views
Last post by MoVolvos
- 3033 Views
Last post by Roger_850T
