2000 s80 t6 dead
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
dshoover2
Year and Model: 2000 s80 t6
Re: 2000 s80 t6 dead
Post by dshoover2 »
where is that located also can i get a used one to work
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Sorry meant to say DIM not CEM though both or either could be faulty in your case. Again VIN matching is necessary.
I believe you can make a used one work, but dealer will need to be involved; again this unit uses the immobiliser module to confirm correct VIN.
You can have XeModex check your unit for you. 8251281 COMBINED INSTRUMENT CLUSTER may be your part number but without a VIN I can't confirm.
Call XeModex and someone can talk you through a test procedure
