1995 850 Idle stumbles and wants to stall, couple codes
rspi
Has thanked: 34 times
Been thanked: 72 times
Re: 1995 850 Idle stumbles and wants to stall, couple codes
Post by rspi »
jblackburn wrote:Also...interesting dash for an 850. I've never seen one like that.
It's the Yakii cluster.
I had a 2 week old ETC go bad on me once. I don't understand how those things work when it comes to the ECU and temp gauge getting signals from it.
marklawder
Year and Model: 1995 850
Post by marklawder »
Problem came back, tested the maf and it was reading a flat voltage not even responding to throttle changes. Replaced it and all is well now. :)
Has thanked: 1503 times
Been thanked: 3817 times
Can you post the pinouts and readings on the MAF for reference for others please?
marklawder
You have to backprobe the sensor while it's still connected. To do this, I pulled the rubber cover back on the connector and stuck two small nails into the wires of pins 2 and 4. Read the voltage between them while car is idling. Should be around 1-1.5 volts. When you open the throttle, it should increase up to 5 volts. Mine was reading 7 volts and didn't change. There's also a youtube video that shows this, search for "bosch maf testing".
