When your fuel light comes on, you put xx.x gallons in
jacobharding
- Year and Model: 87 740 T.I.
For what its worth I have gone 70 miles after the light comes on and STAYS on. I want to carry a can of gas and see just how far it goes before it cuts off one day when I have nothing better to do.
I am not an expert mechanic, but I will attempt any repair. Worst case scenario is I screw it up worse than it was.
87 745 Turbo Intercooler...333k, all original!
96 850 Turbo wagon "totalled - parting out"
94 850 Turbo wagon waiting for tranny
2 94 855's gone
They're all gone now....
2 94 855's gone
Thanatos2489
- Year and Model: V70 AWD 1998
Temperature has a little to do with it as well if it's cold I can get more in then on a hot day but normally get 65 ltrs in my 70 ltr tank
akwon
- Year and Model: 850 GLT 5dr, 1996
- Has thanked: 3 times
The other day I was at the pump and the backflow valve (or whatever it is) wasn't working and gas started pouring out from the filler hole. Not a lot - I let off the handle because it sounded odd and I was expecting the click - but by the time I let go the, gas was already backing up the filler neck. I was pretty low on gas and I got charged for 54.8 L. I probably lost a quarter to a half litre on the ground though.
1996 850 GLT 5dr, 219xxx km and a broken odometer
1st car, 1st Volvo
plan to drive this thing into the ground
1st car, 1st Volvo
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
I always thought the light was an indication to add fuel.
What's one more yellow light on my dash. Mine comes on with my mileage indicator showing about 60 miles to go before running out. Filling a car up is never in my budget. It gets either $20.00 or at the most $40.00 and a time. I do run 87 in mine all the time. Some day it will quit.
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
I never wait until the light comes on anymore. I did that once and had to walk to a gas station in the freezing cold....in flats...never again. I can never fill mine up more than 14 gallons but it says I have a 15 gallon tank.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
By design all fuel tanks are engineered to leave air in the top for expansion, bla bla bla whatever. So, when you fuel the tank and it get "full" and stops the pump, there is some space in the top of the tank. When you keep trying to fill more gas in you violate that designed space and can cause issues.instarx wrote: Because gas flows down the neck to the tank using gravity, the filler neck HAS to be higher than the tank. This seems so obvious, I must not be understanding what you are saying.
When I pulled the filler neck from a Lincoln town car the next went in about about 2 inches from the top. On the Volvo's the neck is a lot lower. The fuel pump access is in the top but not the filler.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
16 u.s. gals.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 1505 times
- Been thanked: 3818 times
Capacity of 1999 V70 FWD from owner manual 18.0 US Gallons
Light came on with computer indicating 50 miles to empty, and 25 mpg (80 mph)
Drove another 12 miles, then filled with 17.6 gallons, so approx 1 gallon to empty when light came on. 50 miles to empty optimistic, perhaps
jacobharding
Wow...80. Is that the speed limit in NYC? 80+ in VA is considered reckless driving and is an arrestable offense.
2 94 855's gone
2 94 855's gone
