96 Volvo 850 Turbo - Died on road and won't start
- osman
- Year and Model: 2002 c70 hardtop
You will need to decide whether you want to walk away, rebuild that motor, or replace with a junkyard motor. Most people choose the latter, some the former, very few people choose the rebuild option as it can be close to the blue book value of the car.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
remove the oil cap and have someone try and start the car, do you see the cam moving? if it is and you hear a wizzing sound then you jumped timing and have no compression in the motor due to bent valves. you can jump about 4 teeth before it starts to run weird, 5 teeth and you may not hear the valves smashing the pistons but the damage is done.
RIP: My Father 10/17/13 The Spiegel Grove claims another Soul.
"We are all the sum of our choices. The fear is not of dying... it is to not have lived."
Forever loved. Never Forgotten.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Sorry to read that your timing belt broke. If you can follow instructions there are some good tutorials out there to walk you through the head replacement.
Could you tell what made the belt break? Was any of the rollers damaged? Do you know how old the belt was?
Also, please let me know if it made any noise? I always tell people that it's a silent death.
angeltease
- Year and Model: 760, 1990
I have a 1990 760 turbo, last week the air intake hose melted and I believe the melted rubber too was sucked into the turbo. My husband changed the hose, now it will start-Sometimes! Runs rough will cut off if you don't stay on the gas....and it will run (kinda) for 3 mins, at which point it doesn't matter how high you had it revved it will just stop...we took it for a test drive an hour ago we drove down the street, which is slightly sloped n turned around at the bottom...my husband gave it some gas to start back up the street n it got no power, almost sounded like it was in neutral then it made 5 or so fast short hisses... ss ss ss ss ss then it cut off
WHAT ?angeltease wrote:I have a 1990 760 turbo, last week the air intake hose melted and I believe the melted rubber too was sucked into the turbo. My husband changed the hose, now it will start-Sometimes! Runs rough will cut off if you don't stay on the gas....and it will run (kinda) for 3 mins, at which point it doesn't matter how high you had it revved it will just stop...we took it for a test drive an hour ago we drove down the street, which is slightly sloped n turned around at the bottom...my husband gave it some gas to start back up the street n it got no power, almost sounded like it was in neutral then it made 5 or so fast short hisses... ss ss ss ss ss then it cut off
You might want to start a post as this is a different subject and basically a hijacked thread,
I am sure folks can help you, But wont be able to find you under someone else's thread,
angeltease
I just figured out how to start a new one
. Thanks for the advice!
- 38 Replies
- 5664 Views
Last post by DaveP189
- 24 Replies
- 3929 Views
Last post by Atis
- 110 Replies
- 17647 Views
Last post by bmdubya1198
- 17 Replies
- 4597 Views
Last post by volvolugnut
- 3619 Views
Last post by lummert
