1999 v70 wagon Relay
Has thanked: 1505 times
Been thanked: 3817 times
Re: 1999 v70 wagon Relay
jdpooley wrote:Thanks for the help! I am new to Volvo's, learning a lot here. So thank you. Sorry, what is MCC or ECC? Sometimes when you turn the car on the fan will not work at all. Fan will not run on low or high.
MCC is manual climate control where you set the temperature and the fan is hard wired to the speed switch
ECC has an AUT position on the central dial and the fan is controlled by Skynet.
Troubleshooting is different
jdpooley
Year and Model: 1999 v70
Post by jdpooley »
Thanks all! It is an ECC unit.
jdpooley
Post by jdpooley »
I put in the new ignition switch over the weekend. Everything seems to be working fine! Thanks again for all the advice!
