1996 850 GLT Need to find vacuum leak >> found
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Re: 1996 850 GLT Need to find vacuum leak >> found
Post by misha »
I tossed mine few years ago. :wink:
Interesting thing is that Volvo stopped putting them in s,v70.All they did in 850(s) was plugging themselves on & on. :mrgreen:
You could probably attach it to any available nipple on a vacuum tree but firstly the nipple on a flame trap must be plugged,otherwise there would be an obvious vacuum leak.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
osmium
Year and Model: 96 850 GLT
Post by osmium »
misha wrote:I tossed mine few years ago. :wink:
Thanks.
Hopefully it'll stay warm enough for me to do this over the weekend.
That leak is making the car a thirsty beast!
-os
1996 850 GLT 262k miles (gone :( )
1999 Honda Civic (gone)
1996 850 GLT (gone, no more Volvos :( )
2000 Buick Park Avenue (gone)
2005 Honda Odyssey (gone)
2013 Lexus ES350 (replaced Volvo 850)
2021 Honda Pilot
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
My dad has this code on his 850 glt and a broken elbow. Which elbow is it? Two are available?
1389574, or 9155862?
If i use a hose where does it connect to? One of the ports with the 4 plugs on the IACV?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
These questions were was addressed in the thread, i.e.
erikv11 wrote:If the elbow is cracked then the PCV tubing may be deteriorating in general. The car may need a PCV servicing and a quick look at all of the vacuum lines.
I think it is the large-small elbow but I wouldn't buy it. Your best bet is to just walk into any auto parts store and get 3 or 4 feet of rubber, 5/16 vacuum line. It will be cheap. Run a fresh piece of line from that nipple in your photo over to where the existing hose connects to the flame trap housing, next to the throttle body. Choose any route you like, under the manifold or around the front. The vac line will last longer, be easier to install, and work better than the thin, hard plastic tubing that is in there now. Just leave the old hose in there.
misha wrote:The other end goes to the nipple on the flame trap.
Or are you asking something else?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
osmium
Post by osmium »
mecheng wrote:My dad has this code on his 850 glt and a broken elbow. Which elbow is it? Two are available?
On mine, the the problem was the vacuum connection on the left side of the intake manifold. That tube goes behind the manifold and connects to the vacuum tree.
I didn't use an elbow to fix it. I got a length of vacuum tubing from O'Reilly's. I needed a pair of long nose needle nose pliers to get the tubing over the nipple on the manifold. I then routed the tubing in front of the manifold and connected it to the same place on the vacuum tree where the original tube connected.
The code hasn't been back since.
-Os
2021 Honda Pilot
mecheng
Post by mecheng »
Is the flame trap the thing that looks like a tree with four branches with nipples?
Is it okay to leave the existing hose open or do I have to plug it? Where does it connect to?
If my dad wants the oem look, does anybody know the part number? Thanks!
osmium
Post by osmium »
mecheng wrote:Is the flame trap the thing that looks like a tree with four branches with nipples?
That's the vacuum tree.
I left the original hose/tube unconnected.
-os
2021 Honda Pilot
mecheng
Post by mecheng »
Ok just to clarify, the OEM hose routes across the turbo into the vacuum tree which is near the throttle body. You remove the 90deg elbow from the intake manifold run your own line across the front of the engine into the same port on the vacuum tree.
Correct?
Thanks
osmium
Post by osmium »
Yes.
2021 Honda Pilot
mecheng
Post by mecheng »
Ok lastly, does anybody know the Volvo part number, I found two elbows both similar. One is small small, the other is big small.
9155862
1389574
