2 months ago replaced all brake fluid using a vacuum pump.
At 325,000kms replaced engine oil and filter. Semi synthetic 10W40
Also used Gibbons method to replace 12L of transmission fluid. Used Penrite Full synthetic fluid. Reset adaptation and fluid counter.
Car has done just over 500kms with no codes from transmission and shift quality is far improved.
Replaced inner CV boot RHS front.
Drain and fill with new coolant.
2002 XC70 SBD 672 Burgundy
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
precopster
- Year and Model: Lots
- Been thanked: 128 times
precopster
327,000kms. Replaced all tyres with 215/65/16 Pace radials in Brisbane while holidaying there. Also performed wheel alignment. Cost $485
precopster
At 330,000s replaced ECM with used one as car was cutting out for unknown reason then starting right up with no codes present. Managed to get a P0159 once which is ECM internal fault.
Henry (Doublebug) assisted to clone my old ECM over the internet. I asked him to retain the new ECMs firmware as it was from a T5 and over here we don't have evap controls for this MY; that saved firmware may come in handy at a later date.
precopster
precopster
At 331,600 replaced 3.8L transmission fluid with Nulon full synthetic.
Cost: $40.00 from Sparesbox
precopster
At 334,000 kms replaced engine oil Castrol 5W-30 & Nulon 10W-40 @ 50:50 ratio both full synthetic. New genuine filter, crush washer and oil cap seal.
Considerable sludge on filter.
Cost: $65.00
Cost: $65.00
