1997 850 abs module/pump removal questions
Has thanked: 292 times
Been thanked: 765 times
Re: 1997 850 abs module/pump removal questions
Post by erikv11 »
Yes, the threads are only in the pump unit. So once you grind the head off the module drops right out (ask me how I know ...), and you will be able to easily turn out the bolt by hand right away (probably) or after getting it started with a pair of pliers (for certain).
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
thedancingfiddle
Year and Model: 1997 NA 850 wagon
Post by thedancingfiddle »
Ok cool. Any suggestions on dremel bits to do this with?
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Small grinding bit. They make one that's about the same size as th head of the bolt. I usually use the carbide grinding bit.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
thedancingfiddle
Thanks Matt!
Ok, that will be my next plan of attack. I won't have a chance to work on it until next week, but hopefully I'll then get it off and be in touch to send it to you for repair.
joe_pinehill
Year and Model: 850 1996
Post by joe_pinehill »
I had the same issue, the three most accessible screws came right out, the lower right screw stripped. I have a Foredom Flex Shaft tool, and tried several attempts with mirrors, lots of Mother of Pearls, I gave up trying from the top. Between the angle and everything being backwards with a mirror, it was too frustrating for me.
I put the car on ramps, and it was much easier to access the lower screw. With flex tool ( a dremel would also work) and carbide tip cutter, I ground out the old head.
Buy stainless screws to replace the torx head.
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
What is torque on these screws?
If below 20ft-lb, then vise-grip will do the job.
joe_pinehill
xHeart wrote:What is torque on these screws?
its access that is the issue, the torque is very low.
Luckily Volvo did place the ABS so you can remove the module. I looked at my 2008 Outback, the ABS electronic faced the front strut housing. There is no way to remove it without taking the entire hydraulic ABS block out of the car.
96 850 GLT
thedancingfiddle
joe_pinehill wrote:I had the same issue, the three most accessible screws came right out, the lower right screw stripped.
Which screw are you referring to as the lower right? The problem one on my car is the lower one towards the front of the car. I guess it would be the 'right' if you looked at it from the side the module is on, or 'left' if you're looking at it from the drivers side of the car....
Post by erikv11 »
Lower front is the one everybody has trouble with, because it is more difficult to access. I had to grind it off, I used a Dremel, it was a hassle and the module wasn't pretty coming out of it but I was able to get it done and I bet you will be too. There is actually a lot of easy real estate in there on an NA like yours.
I always just buy standard hex bolts to replace the torx ones, is there a good reason to use stainless?
'06 S60 R, 197k
joe_pinehill
Which screw are you referring to as the lower right? The problem one on my car is the lower one towards the front of the car. I guess it would be the 'right' if you looked at it from the side the module is on, or 'left' if you're looking at it from the drivers side of the car....[/quote]
the bottom screw clostest to the firewall
96 850 GLT
