Use a rubber hose to isolate the noise to make sure it's the belt is whining and not the idler pulley.
They whine, grumble, then self- immolate...which takes out the rest of your engine when that happens.
2000 usd fix required after that
1995 850GLT Timing belt rubbing
- Has thanked: 1502 times
- Been thanked: 3817 times
Re: 1995 850GLT Timing belt rubbing
- Year and Model: Many Volvos
- Been thanked: 75 times
I can see that now that you pointed it out. The bad tensioner roller caused the belt to track a bit off of the camshaft pulleys but it didn't have a problem at the bottom. I haven't seen one rub the harmonic balancer before but my guess is that the water pump is askew. On this one I think I would change everything.alcapwn1010 wrote:Well in the top picture where the belt wraps under the crankshaft and comes back up, it's rubbing against the main pulley for the accessory belt.
- 2214 Views
Last post by other_shoe
- 4267 Views
Last post by jimmy57
