2001 XC70 Cranks but won't start
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Has thanked: 1497 times
Been thanked: 3810 times
Re: 2001 XC70 Cranks but won't start
You need to go back to basic no start troubleshooting, which coincidentally we are in the middle of developing a master thread on the P80 forum
Compression, fuel, spark, timing
There are several posts on other fora where people report DICE clones giving spurious error codes especially the COM errors on otherwise well running cars.
altalake
Year and Model: 2004 XC70
Has thanked: 2 times
Been thanked: 3 times
Post by altalake »
Possibly solved. After countless hours, diagnostics & clearing codes (not necessarily reliable with DICE clone), checking and cleaning connections (everything looking good), $300 worth of unnecessary parts and at least one tow truck, this showed up: loose ground screw inside the Upper Electronics Module (UEM) - the computer which is behind the lights next to the rear view mirror. Loose ground = intermittent problem, but is this something which would keep the car from firing up (about 10% of the time) and yet let it run when it does catch?
Yes, exactly that.
Pretty soon Im going to start a tally of 'fancy problems' vs bad wires/grounds.
Right now, its about 999-1 for grounds
altalake
Post by altalake »
Misguided optimism. Ground @ UEM disconnected and car started fine. Ground reconnected and car started a few times and now won't start - usual crank but no fire. Back to the drawing board.
altalake
Post by altalake »
Looking for more ground connections. Checked battery, 6 points on either side of the engine, main lead to engine and UEM lead (this one doesn't actually ground the UEM itself but feeds off to 2 other locations). Locations of others ground points not so obvious? (this car is a 2001 V70)
regent
Year and Model: 2015 XC60 T5
Been thanked: 12 times
Post by regent »
I say you look for some help with your electrical here: http://www.volvowiringdiagrams.com/?dir=
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
altalake
Post by altalake »
Problem still unsolved but changed somewhat. This is either an additional problem or a variation of the 'cranks but does not start'. That issue, when it occurs during about 5% of starting attempts, will persist for 5 minutes to 48 hours, typically about 6 to 12 hours. No sequence of keys, locking/unlocking, battery disconnecting/reconnecting, tapping fuel pump, wiggling wiring, swapping relays has ever got it started - but it still eventually starts and runs fine when it does. No unburnt fuel smell so it seems fuel is not getting to the cylinders.
Now the car stalls periodically - 3 to 4 times in 15 minutes of driving. In one case an immobilizer message came up on the dash but on all subsequent events there have been no warning lights, all gauges appear normal until the car stops or I press the clutch so the engine can stop. After this the car will crank but not start but, if left alone for about 2 minutes, will start.
If there were no electronics it would seem like a simple fuel problem but the engine revs up over 5,000rpm easily on a hill climb and never misses - it's either all good or nothing at all. Fuel pressure about 50psi which is within specs.
Ideas?
altalake
Post by altalake »
Anybody know where the Fuel Pump Electronic Module (controller) aka PEM might be located on a 2001 V70? Supposed to be under the car in the cavity between the fuel filter and gas tank but is not there. Retrofit is supposed to be in spare tire well but it's not there. Some XC's have it in the RF corner where the alarm siren is located but I'm hoping for something more accessible. This car is a FWD V70 T5 (not XC), manual transmission. Maybe it doesn't actually have a separate PEM? (although VIDA shows a part number for it - but also shows it next to the fuel filter)
I have the same car, but 1999. I think the 1999-2001 are the same. I'll look mine over and see if I can find it this weekend, on travel
On edit...got that wrong, I think you are P2 chassis right??
altalake
Post by altalake »
Just got word back from a dealer. Apparently I can't find the PEM because it doesn't have one. Circuit now controlled by the CEM.
Yes, it's a P2.
