1999 S70r poor running MVSolved - bad ground
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: 99 S70r motor stuck!
Post by MoVolvos »
b2fkb0 wrote:
What kind of gloves are you wearing or cleaner using. The fingers are CLEAN.
_
UPDATE: Btw your shop is very clean also for the amount of work you're doing! When I worked at Acura my Manager would asked me to get my tools dirty. That's almost twenty years ago and I've since let things go a quite a bit :roll: .
b2fkb0
Year and Model: V70r,855r,s70t5m,xc
Has thanked: 5 times
Been thanked: 4 times
Post by b2fkb0 »
I use harbor freight nitrile gloves. They actually save time by keeping my hands clean. My garage is attached to the house so I keep it clean to help keep the house clean. A friend showed me that powdered laundry soap works great at lifting oil and grease off the floor. Wet the floor, dust over with the soap, broom around lightly with focus on oily spots. Let sit an hour and rinse. Works great!
MoVolvos
Post by MoVolvos »
_
Thanks, I'll give the cleaning a try!
_
b2fkb0
Post by b2fkb0 »
Worked again on the motor today, decided to port the intake
Put the etm on and ready for installation tonite!
More to come!
b2fkb0
Post by b2fkb0 »
New fluid for the m56
Intake is on
Lubed up the bushings on the Snabb short shift kit
Details
Put in coolant and had a big leak at the heater hose connection; seems I brushed the hoses and that fragile fitting broke. Not to be stopped, spent a couple of hours with this workaround
Next up is the k24!
deepsouth
Year and Model: 2001 Volvo XC70
Been thanked: 8 times
Post by deepsouth »
Good thread! I've been debating a swap. How much was the motor?
Eric
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
b2fkb0
Post by b2fkb0 »
I got the motor, turbo and ecu for $330. Took 5 hours total to check it over, pull it, load it and bring it home!
b2fkb0
Post by b2fkb0 »
Well it's running but not well! Ets and stc lights are on, tach drops out after 10 seconds of running and motor stumbles. Scanned and there are "no codes"! Any help is appreciated!
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I didn't know this was your thread.
You have a loose ground wire to have those two coming on at the same time.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
b2fkb0
Post by b2fkb0 »
Thanks Matt, I'll check those again.
