2002 S60 Both front wheels have play.
- Has thanked: 2205 times
If you replace the control arms I would always replace the ball-joint as a matter of course. The cost is less than that of an alignment and the work needs to be done to replace anyway.
The inner and out tie-rods unfortunately do wear and at the mileage you are at they could be past their best. There is a fair bit of work in replacing the inners, but the outers are easier.
Both will cause a vagueness with the steering, and a good chance of greater wear on your front tires.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
How are the 4 front subframe bushings?
- regent
- Has thanked: 2 times
- Been thanked: 12 times
I am fixing on doing the tierods on my '02 S60 while changing control arms and ball joints and a few other things.
Can anyone give some insight on the inner tirods; my concern is with the pipe wrench method without counterhold on the steering rack: Is there any risk of damaging the rack-and-pinion assembly by putting torque through it?
All videos I've seen show similar methods with no counterhold (as opposed to the VIDA procedure which calls for the special counterhold tool)
(This may seem on the paranoid side but I would welcome any input.) Thanks in advance.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- regent
Well, does the tool include the counterhold? Like I mentioned, I am not comfortable with putting stress on the rack itself when undoing and installing the tierod
2015 BMW 335i
2015 BMW 335i
- 624 Views
Last post by SuperHerman
- 635 Views
- 208 Views
- 1153 Views
Last post by Krons
- 971 Views
Last post by instarx
