99 S70 T5 Why are the rear disks bigger than the fronts?
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Re: 99 S70 T5 Why are the rear disks bigger than the fronts
Post by cn90 »
Then prove it with photos for FRONT and REAR with measurement tape in the photos...
dosbricks
Been thanked: 2 times
Post by dosbricks »
Tim, I went out and measured our S70 (not a T5) with a large machinist's caliper and the rear rotors were about 1/2" larger diameter than the fronts--most likely due to the aforementioned e-brake housed in the rear centers. However the pad contact surface is greater on the front squeezing on about the same width band on each rotor. So if we can extrapolate that front/rear engineering up from the S70 280mm fronts to the T5 302mm fronts, then it could make sense that your rear rotors are also larger diameter than the fronts.
Now all you guys need to hug and make up. :P
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Yeah, this thread got really angry really fast. I thought only JRL could elicit such hostility. :P
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
dosbricks wrote:Tim, I went out and measured our S70 (not a T5) with a large machinist's caliper and the rear rotors were about 1/2" larger diameter than the fronts--most likely due to the aforementioned e-brake housed in the rear centers. However the pad contact surface is greater on the front squeezing on about the same width band on each rotor. So if we can extrapolate that front/rear engineering up from the S70 280mm fronts to the T5 302mm fronts, then it could make sense that your rear rotors are also larger diameter than the fronts.
A handful of T5's had the "big brake kit" from the factory. Most were still just the standard 280mm.
'98 S70 T5
2016 Chevy Cruze Premier
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
But aren't those kits just the fronts?
Never heard of anything special on the
back except the vented rotors on '00 R's.
jblackburn
BEJinFbk wrote:But aren't those kits just the fronts?
Yeah
'98 S70 T5
