2001 V70 Cabin Ventilation stopped working
- regent
- Has thanked: 2 times
- Been thanked: 12 times
I am not sure what exactly you found (I hope you identified a poor connection and fixed it so it won't come back on you). Since your vent servomotors and lights are now working, the ground should not be a concern.
Your next step is to get to the fan electrical connector and check power to the fan assembly. The connector is accessible from underneath the glovebox (like when you change the cabin filter) without having to pull the fan assembly or anything else (at least not yet).
Once you've confirmed that the power supply and the control are both OK, then you will know it's a bad fan motor or a bad speed regulator. (You will still need to pull the fan assembly out to get to the electronic regulator). The diagnostic approach at that stage is pretty straightforward, and the actual work requires small hands, a lot of patience... and certain select phrases
found in the underground French vocabulary...
...but it feels pretty rewarding when you're all done!
Sometimes (if the fan motor gets stuck because of a foreign object or a bearing failure) it would overload and take out the regulator so you may end up having to replace both; however that is seldom the case.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- regent
Yes,
Please find attached VIDA Procedure Files.
I believe you can find a very decent wrire-up if you search around, with some shortcuts, photos, and explanatory notes.
Cheers!
Cheers!
2001 V70 Blower Fan.pdf- (144.12 KiB) Downloaded 142 times
2001 V70 Console.pdf- (447.75 KiB) Downloaded 348 times
2001 V70 Glovebox.pdf- (77.03 KiB) Downloaded 750 times
2001 V70 Sill Trim.pdf- (100.01 KiB) Downloaded 115 times
2001 V70 Soundproofing Panel.pdf- (102.11 KiB) Downloaded 121 times
2015 BMW 335i
2015 BMW 335i
- 2234 Views
Last post by Sixthandredline
- 678 Views
Last post by oragex
- 1578 Views
- 875 Views
- 11 Replies
- 1631 Views
Last post by Acetheprince
