99 S70 What hose did I blow?
Re: 99 S70 What hose did I blow?
Thanks Regent. As soon as I noticed the hose blown and the AC quit working, I powered the AC off from the climate control panel. Is there a fuse I could pull that would keep it from engaging or better to just disconnect the wire?
- regent
- Has thanked: 2 times
- Been thanked: 12 times
If you be the only driver then you know " you won't push that button"
To be safe, I'd wanna pull the wire off the coil teerminal just in case I forget
There is a fuse but I do not have your prints right now to see if that circuit is dedicated to the clutch
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- regent
In theory, it would not even start at all without pressure but I am super extra paranoid...
2015 BMW 335i
2015 BMW 335i
- Has thanked: 1503 times
- Been thanked: 3817 times
The low pressure switch being at atmospheric pressure will prevent the clutch from pulling in. More correctly, on a 99, the low pressure switch will tell the ECU not to engage the clutch.
- 17 Replies
- 1462 Views
Last post by tjmartin317
- 2820 Views
Last post by rspi
