S70 DIY: Boost Gauge Install - complete guide
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Re: S70 DIY: Boost Gauge Install - complete guide
Post by mecheng »
erikv11 wrote:Those look like the factory clamps on your IAC hoses, if so you may wish to remove them to pull it out and give it a good cleaning.
They are, I sprayed a lot of TB cleaner through the vacuum tree nipples while the car was running thinking it would clean the IAC: the engine stumbled so I know it was making its way to the throttle body. I would think this works okay.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Interesting idea, yes maybe it will do the job.
BTW thanks for putting together this write-up, it's great.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
mecheng
Post by mecheng »
Thanks everyone, it was a fun project. I agree, if you are a car guy/gal the gauge is great to have. It's fun watching it, especially when it climbs of course!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2653 times
Been thanked: 1247 times
Post by matthew1 »
Excellent tutorial. Scheduled for inclusion in the Repair Database.
Also -> Amazon link
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Super write up, thanks. I always wanted a boost gauge and I think I'm going to order one now. :D
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
mecheng
Post by mecheng »
rmmagow wrote:Sweet write up. The boost numbers, when you hit the peak is it the TCV that takes over and cuts it back to 10 or so? Is the waste gate adjustment what lets the peak go a bit higher? That's a nice looking clean install. I think I'm going to try this on my 98 AWD.
I did a test with the stock waste gate setting and it had no effect on peak boost, but the car feels sluggish in the midrange, so it only affects how quick the boost builds. I changed it to one turn after the test.
sleuth007
Year and Model: 1998 S70 T5 SE
Post by sleuth007 »
Given the variety of pods and fitment issues, it would be nice if you could state the specific part number /source for the Lotek Inc part. The meter you used which was 2 1/16" in diameter was easy to find on Amazon however.
In other words you took the time to drill down and find a nice combination of gauge face /color /style which needs to fit "exactly" into the pod hole without a bracket. At this price point and given the professional manner / care of your install, I am surprised you would consider turns of tape to make the fit "right".
Or did I simply miss the details I seek somewhere else in your posting?
mecheng
Post by mecheng »
sleuth007 wrote:Given the variety of pods and fitment issues, it would be nice if you could state the specific part number /source for the Lotek Inc part. The meter you used which was 2 1/16" in diameter was easy to find on Amazon however.
There is no Lotek part number, you just select the pod for your car. They have a pod for both the 850 and S70.
The tape is only a recommendation if your gauge fits small to the gauge pod hole. My gauge was tight, I just wrote that as a recommendation if you have a lose fit as there is not enough room behind the gauge to secure a bracket. If you buy a no name gauge (there are plenty out there) you may have a slightly smaller OD causing it to be lose.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Thanks for the great writeup! I did this today on my V70 GLT, and everything works! I still have to run the wires for the backlight, though. I ran the hose up the dash, and behind the weather strip, and it all looks nice and clean.
I used the Harbor Freight boost gauge, and they give you JUST enough hose to make it from the vacuum tree to the a-pillar. It took a little while for me to find the under-dash end of the pass-through, but it's fairly easy to find if you look. It's just behind the relay panel.
bmdubya1198
In addition to this DIY, if you have a cheap boost gauge like I do (Harbor Freight) and it has 3 wires, you cannot use the pink wire for power. The dimmer wire goes to pink, ground goes to black, and the power wire goes to one of the salmon-colored wires with the black stripe. I successfully wired it up this past weekend, and everything works great!
