98 S70 Stalls with no CEL
Has thanked: 1611 times
Been thanked: 4074 times
The data comparing idle time with wire vs relay probably doesn't mean too much. Measure they fuel pressure at the rail to confirm good pressure, then move to ignition system testing
How old are plugs, cap rotor and your Bougicord plug wires?
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Have you ever changed the fuel filter? It could be very plugged up if it's never been swapped out. I'd try that first before getting deep into fuel pump issues.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
styoung94
Year and Model: 1998 S70
Post by styoung94 »
abscate wrote:The data comparing idle time with wire vs relay probably doesn't mean too much. Measure they fuel pressure at the rail to confirm good pressure, then move to ignition system testing
I'll check the fuel pressure later today, I'll pick up a cheap tire gauge to check it so I don't ruin my good one.
I'm not sure on the age of the plugs, cap rotors, or the plug wires. I got the car three years ago and haven't messed with anything. Not sure what the previous owner(s) did aside from a bunch of new suspension work.
rmmagow wrote:Have you ever changed the fuel filter? It could be very plugged up if it's never been swapped out. I'd try that first before getting deep into fuel pump issues.
I've never changed the fuel filter but I'll order one of those and swap it out.
styoung94
Post by styoung94 »
Alright so I've figured it out. It's the mass airflow sensor. It will run normally when the MAF is unplugged, aside from the check engine light and starting a little rough. It drive normally with it unplugged. Gonna purchase a new one tonight once I shop around for a little. Any inputs on which one? I think I'll just get the stock Bosch one.
Thanks everyone for all the input and advice.
rmmagow
Post by rmmagow »
No question, stock BOSCH unit, don't even think of an ebay special.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
+14,000
Gotta get the Bosch.
styoung94
Post by styoung94 »
Sounds good. I ordered the Bosch.
Thanks again for all the input.
