Perfect crank alignment for volvo s70
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
I can't believe in this days and age, people still have problem using google...
Found using the https://www.google.com/search?q=s70+tim ... 80&bih=666
Took 30 seconds to scroll thru the pictures.
http://s1165.photobucket.com/user/jsgon ... 2.jpg.html
http://smg.photobucket.com/user/mustang ... 2.jpg.html
85 GLH, 367 whp
00 Insight, 72 mpg
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
What's Goggle? Never heard of it. :oops:
VolvoS70BASE
Year and Model: 1999 s70
Post by VolvoS70BASE »
Dont know why people need to crticize on forum after all no one is perfect have seen rspi make several errors in his videos every post i did google says about bump that precopster posted pic of aligning with mark on oil pump housing. So is just having the valley and oil pump housing mark aligned good or do you need the bump the precopster showed aligned as well
precopster
It's not really a question of whether the bump can be used or not. It's a question of accuracy. The bump on the crank pulley and the bump on the oil pump are too far away from each other to align accurately, unless you have the world's smallest head. If the engine is off the car it would be fine.
By just using the bump you may end up one tooth off.
Using the bump for rough alignment then using the notches for final adjustment is the way to achieve what the title of this thread is about.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
VolvoS70BASE wrote:... So is just having the valley and oil pump housing mark aligned good ? ...
Yep, that's all you need to be sure of.
