1998 S70 OEM Diagnostic Scan Tool
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
precopster wrote:The most annoying aspect of a VOL-FCR system for the novice user is that it won't reset the service light on Moronic 4.4
Demo version will not reset service light.Cracked version works on Motronic 4.4.I have it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Ben850
Been thanked: 7 times
Post by Ben850 »
Yes. The demo version does nothing that is very useful.
It does give an explanation of how to use an OBD I flash reader, which, if you have not yet created is also of useless information.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
North42g wrote:...1998 S70 2.4L; the dash board is lit up lick a Christmas tree! SRS light illuminated, ABS/TRAC lights Illuminated, MIL/CEL & finally the "Service" light is blinking.
As far as the ABS/TRAC light is concerned, I have read the posts and fixes for the ABS module. And I performed it. I removed the module from the pump & soldered the joints as instructed. It worked! However, it was short lived. 13 days later, the Fault lights returned.
- The Christmas tree thingy: check all your ground wires. Diagrams in forum.
- The ABS thingy: I did the same thing (soldering but short-lived), I sent my ABS module to BBA-reman dot com Taunton, MA, north of Boston). They fixed it for $60 with LT warranty.
Three years later, all is good, these guys are BBA-reman knows what they are doing.
- For 98 model, all you need is the standard OBD-II scanner, which I am sure you know.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
For a 98 nothing is perfect. VOL-FCR works about the best, for me at least. My autel EU702 won't clear ABS codes on a 98 but will clear SRS, OBD and TCU codes no problem. I did just buy an Autel AL619 this week that will clear ABS on a 98 but it can't read TCU codes like the EU702 can. The AL619 is also "clunky" in how it's set up, I'm thinking I'm not going to keep it as it isn't fast enough for me.
I have Vida/dice, FCR, EU702 and now the AL619. None of them are perfect for any given situation on any car. I actually strongly dislike VIDA and won't use it unless I absolutely have to.
FCR can be free if you don't count the cable. That's still cheaper than a basic $20 reader and about the best that any of us are going to get.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
North42g
Year and Model: 850 GLT, 1995
Post by North42g »
Thanks all of you! lots of good info....
as technician , I sometimes have trouble finding time or wanting to find time to fix my own cars...the cobbler and his shoes...
I now have good direction to purchase the right stuff, thanks again guys!
MERRY CHRISTMAS and so forth and so on...
1995 850 GLT Estate -190k
1998 S70 -233k
2003 VW Jetta 2.0L -130k
1994 Saturn SC1 -288k ..and still going strong
1969 Ford Bronco 302 -119k
