1997 850 Brakes thumping?
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
davolvo wrote:The only way I can explain it is that when I am on an open road and there is a stop sign I can hear a noise, it almost sounds like it coming from the front right, that sounds like my tire went flat. It is a real dull thud, thud, thud. However, when I am in town and am going at a slower speed, I do not notice it as much, if at all.
I have named it The Red Baron phenomena.
It will become persistent at all speed, and visibly louder with time.
Look for wheel hub assembly, and replace in pairs.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Sad to say, I have actually seen cracked rotors that cause this noise/feeling as well.
davolvo
Year and Model: 1997 850 Sedan Base
Post by davolvo »
Ok, the garage told me it is a warped rear rotor, he even let me see the difference between the two and feel them. He told me that if I am going to do it, I might as well do both sides and since everything looks original, he suggested the calipers and pads be changed as well. What do you all think about that? I am a firm believer that it is not good to change just one of anything if there is more; might as well get it all done Right?
Proud owner of a 1997 850 Sedan Base
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I agree only change the rotors in pairs.
No harm in changing the pads of course, but I wouldn't change the rear pads if there was life (thickness) left in them. The rears wear slowly and do maybe 30% (?) of the braking; even with new rotors I'd probably stick with the old pads, because I'm frugal.
Your call on the calipers. I would probably not replace them just because they are old, but I might if they were especially rusty. I haven't yet had a caliper seize up on me but others have. That's when I intend to replace them, when one starts dragging.
davolvo
Post by davolvo »
Yes, they are getting rusty.
rspi
Post by rspi »
They all have light surface rust. If the rust looks like chunks of rust can be pealed or flaked off, that is the kind of rust that would warrant replacement.
