1988 Volvo 245DL Overdrive
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
No 4th, especially when it begins intermittently failing and solenoid and wiring is eliminated, can be that the seals for the 4th (OD) clutch are worn or the friction linings are worn.
If it is hardened seals then the products that you add to fluid to rejuvenate seals is a worthwhile gamble.
I have no favored product but Lucas makes a product and another one that has been around for years is Trans-Medic.
I am assuming that the power supply to the 4th (OD) solenoid has been checked. That year should have power to solenoid in order to have 4th gear.
jimmy57
Post by jimmy57 »
Do the additive first. it will work with the old fluid. If it doesn't work you won't have wasted time or money.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Just make sure that only the larger of the 2 o-rings get's installed.
1988 Volvo 760 Turbo Wagon
