2000 v70xc (215k) decisions, decisions..what to do???
mrscullini
Year and Model: 05 XC70, 08 XC70
Has thanked: 1 time
Re: 2000 v70xc (215k) decisions, decisions..what to do???
Post by mrscullini »
misha wrote:It can be two cases....tensioner failed or it hasn't been set to a proper tension.
What is the brand of the tensioner?
Oem or aftermarket?
can't remember brand...likely an aftermarket from FCP or IPD. it is stamped "FPM", "INA", "Slovakia" among other things.
with the pistons dinged and 215k on the clock, do you think it is worth rebuilding the head and reassembly or should i just move on?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Well, I have 268,000 and running strong. If the car is nice, I'd fix it.
mrscullini
Has thanked: 1 time
rspi wrote:Well, I have 268,000 and running strong. If the car is nice, I'd fix it.
thanks rspi. i'm really torn as to what to do. i have about 1/3 of the work done with the tear down. i figure about $1500 in parts/labor to rebuild the head, gasket kit, timing components, misc parts, etc. the unknown, which seems unlikely, did the bottom end or piston/rings sustain damage.
the car is in fair conditions, not sure i would call it "nice". let me list the issues and see what folks would do...
leaking rear main seal
minor body issues
door panels
headliner
cracked dash
cracked/weathered upholstrey
rear hatch lock busted
nagging tcv code
prolly needs o2 sensors and a maf (not in the $1500 above)
compression at about 175k miles was about 160 in each cylinder
between the leak and was is burned, consume about a quart every 1500 miles or so (figured it was self-changing)
have quite a bit of carbon build up over the last 40k miles
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Buy parts car for around 350-500$ and use whatever your car needs,especially the head,or just buy used head from junkyard.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
dosbricks
Been thanked: 2 times
Post by dosbricks »
Even if the car had few cosmetic issues, at 215k and with that list of existing conditions--especially leaking rear main seal and oil consumption--IMHO, it would be time to move on and find a suitable replacement that needed less extensive work.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
It's surely a personal matter. Given the amount of work needed, I'd sell it for parts.
If most everything was running good, I would have put a new head on it.
db130
Year and Model: 2002 V70 T5
Post by db130 »
Given the other listed needs, I think it's time to move on as well.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
rspi
Post by rspi »
If you can afford to move on, do so.
mrscullini
Has thanked: 1 time
thanks for all the input, much appreciated.
something that has been bugging me since i pulled the head. only the exhaust valves (and all 10) crashed, no intake valves. if the t-belt slipped, i would think both cams would lose timing and intake valves would crash also.
any thoughts?
misha
Post by misha »
It happens,there are no rules.
It might happen that all of them could be ok.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
