The gas mileage on these cars varies very much depending on your driving style and what kind of driving you do.
I manage to get 23.5 mpg on my commute which is 1/3 back roads and 2/3 highway. This is without AWD, with AWD it is 23 mpg.
On the other hand, our brand new 99 XC used to get only 19 mpg average because it was used less on highway but more city and mixed driving.
If you floor it all the time and never take it on the highway your mpg sounds about right.
You have a very nice XC by the way! I like the color combination and the upgrades that you did.
Good luck with the cat install. I will follow this closely because I can see myself having to deal with this at some point.
Dirk
1998 V70xc catalytic converter job
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
pedal2metal
- Year and Model: 1998 V70xc
Thanks Dirk; I liked the colors too, but regret that I bought it in a spur of the moment type deal. I paid 4k for it (148k miles at the time w/ new timing belt/h2O pump & new battery). Of course after I bought it several 99-00 XCs came up for sale near me for 2k range w/ less miles. Oh well, live & learn. Well I started the cat job tonight & it is already a pain in the butt. I'll take pics and document everything as I go along.
'98 V70xc, '03 gti 1.8t, '99 F150, '90 Corrado, '80 Scirocco
deepsouth
- Year and Model: 2001 Volvo XC70
- Been thanked: 11 times
I did this on my 1998 AWD V70 and it was an absolute PITA. I couldn't get it around the bevel gear and ended up using a cutting tool. Of course, I didn't put in a replacement cat, rather rigged up a straight pipe with a resonator and a welded in O2 bung.
https://www.matthewsvolvosite.com/forums ... =1&t=59607
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
2001 XC70, 129,000
pedal2metal
You are not kidding! I spent all day on yanking the old downpipe/cat unit out... all day! What a pain in the backside (& my neck). I think this new unit will snake around the bevel gear box, it appears. God, I hope so.... I'm documaenting this nightmare. I took the old leaking turbo out to put a 16t in & that helped to make some room.
pedal2metal
Ok, I got the new downpipe in... I had to remove the bevel gear case. (fun) Now I might dump the oil out of that and put in some fresh. I think I read 75/90wt that most people use?
- Year and Model: Many Volvos
- Been thanked: 76 times
I use 75W90 GL-5 which is synthetic. I think I used Royal Purple since I had some laying around.
There may be a drain on gear if it has been modified. The modification was to remove the bottom stud and drill a hole though it that is slightly smaller than the stud itself. The stud then gets wrapped with teflon tape and re-installed to seal the newly drilled hole. I drilled mine out while the transfer case was out since it was easier to get the drill lined up and not mess up the threads.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Don't forget to take the dead cat (you see what I did there . . . ) to the local scrapyard. There's a fair bit of precious metal in there. Got $70 for mine when I scrapped it.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
pedal2metal
Thank you! There is the fill hole, so I was just going to tip the case over & drain it from there since it's out laying on the garage floor. I highly doubt I'd ever do it again. I am hoping it'll last a couple more years; no car payments is nice. This car most likely does not have tapped hole; I'll have to look though. (I think it was your post I found one time talking about that) Is that aluminum box a dampener? The people who owned it before me, did ZERO to this poor car to keep it maintained. It saddens me the more crap I find with it...Ozark Lee wrote:I use 75W90 GL-5 which is synthetic. I think I used Royal Purple since I had some laying around.
pedal2metal
Oh, I'm all about the scrapping! lol. I have box of well pump wire, a bucket of brass, some copper & a few old car batts. to go as well; Thank you for reminding me!! -RoyceE Showell wrote:Don't forget to take the dead cat (you see what I did there . . . ) to the local scrapyard. There's a fair bit of precious metal in there. Got $70 for mine when I scrapped it.
- 850 LPT
I believe it's called a counter balance weight, but I'm not totally sure. Just some extra weight to drag your mpg's downIs that aluminum box a dampener?
BTW, how are the seals on that bevel gear? Now's the time to change them if it's leaking.
I did that on mine, but a few thousand miles later it fell apart anyways.
Glad you got that cat in.
13' Honda Odyssey
13' Honda Odyssey
- 4907 Views
Last post by MadeInJapan
- 15 Replies
- 4779 Views
Last post by DoggyB22
- 1181 Views
Last post by dcmike
- 18 Replies
- 7641 Views
- 5251 Views
Last post by jimmy57
