Pcv
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There is a pcv oil passage inside the oil pan as well, which can be checked without removing the pan at the time of replacing the pcv box. If the pcv box was solidly clogged, there is good chances the oil passage inside the oil pan is clogged as well. only way to clean it is to remove the oil pan.
JRL
- Year and Model: Several
- Been thanked: 16 times
Not true
You can make a simple homemade tool to pull the crud out of that passage when you do a new complete breather
precopster
- Year and Model: Lots
- Been thanked: 128 times
Thin guage wire double twisted can get into all sorts of crevices. Used this method recently as well as compressed air to blow it out. Result was very good.
- 2390 Views
Last post by mickjenkins
- 7529 Views
Last post by Nanjo
- 3074 Views
Last post by rmmagow
- 555 Views
Last post by Ozark Lee
- 63 Replies
- 14408 Views
