There is no valve in the PTC.cn90 wrote:...
- Cleaning the PTC does not mean it works, check to be sure the PTC valve operates properly. ....
Inside the PTC there is just a metal plate with a narrow hole in it. It's basically just a nipple, that's it, hence the name "PTC nipple."
The little electrical plug provides power to heat the metal moderately. The heat helps to prevent freezing at low temperature (cool air from the intercooler could do that), and maybe helps vaporize gases coming through the small tube.
So indeed, if the PTC is clean on all sides then it works. Well, unless somehow the heater has gone out, that could be an issue in some conditions, but I have never heard of an electrical issue at the PTC.
