V/S 70s -- Thoughts on Preventive Maintenance -- Brakes
MrPc
Year and Model: 850R 1996
Been thanked: 2 times
Post by MrPc »
Reading this, I feel like I got lucky when I replaced my brake hoses--I managed to change both fronts and rears and bleed the system in a short afternoon.
The rear hose over the delta link was the most daunting. It was in good shape, and I approached it with a "what the heck" attitude. I had already ordered the part and figured I could just leave the old one in if I couldn't remove it. It did take some patience, and a good flare nut wrench, but I found it wasn't nearly as hard I was expecting.
One of the secrets to my good luck is having a Pacific Northwest car. There was practically no corrosion on any of the fittings. If rust or the need or great leverage had been involved, I suspect I would still be running the old delta link hose, or still be under the car...
Red Red '96 855R, 169k
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
I agree, it's going to vary car by car, some may be impossible some pretty easy, you won't know until you try.
Last fall when I dismantled the rear brakes on my parts car while it was in the driveway, I did not have much trouble with the brake hose above the delta link so I was able to just remove it all piece by piece, from caliper to metal lines to hose (I threw out the hose, kept the lines and calipers). I think it took about an hour and a half to remove everything, including the rear hubs.
Has thanked: 1611 times
Been thanked: 4074 times
Don't forget to replace all the brake fluid on major brake work - its due every 2 years!!
The delta link design on the p80 is a wonderful marriage of design, simplicity, and performance. Basically, two major wear parts.
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Yet the design never really got popular, right?
1996 855 R,
2010 V70 D5,
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
I would never allow my rear suspension to get into the deplorable sort of condition this one pictured is in.
Some people just don't maintain their Volvos. ;-)
cn90 wrote: 17 Apr 2015, 08:58 Further to what I said above...
I "borrowed" this photo from the web to show you how I'd approach the hose above delta link.
All U.S. market models.
All running and on the road.
Eddystone wrote: 08 Apr 2021, 10:05 I would never allow my rear suspension to get into the deplorable sort of condition this one pictured is in.
Look at the grease stains on those delta links....horrible
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Learn me something here about this geometry please.
If one wheel is at full droop (as in extreme cornering), is the lateral link from the opposite side affected to the point it changes camber or toe? There's a "bit" of a swing arm length from the bushing to where the cross link is attached.
BlackBart wrote: 11 Apr 2021, 19:59 Learn me something here about this geometry please.
I think that’s right but the weight of the wheel would be so small compared to the cornering force I think they thought this through in the design. These cars certainly corner on rails.
The rear sway bar also helps on that if you have it
befarrer
Year and Model: 1998 V70 AWD
Has thanked: 1 time
Been thanked: 24 times
Post by befarrer »
Wow, one thing that is easier on AWD cars. Rear brake hoses. But there are 2 on them. As for the rear suspension, I think the design of the AWD multi link rear suspension significantly increases camber on compression due to the unequal length upper and lower control arms, and also increases toe due to the longer rear lower toe rod.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
