1998 V70 Rear Wheel Rotor Replacement
This topic is in the MVS Volvo Repair Database » Parking Brake Shoe Making Noise
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi,
Wow some very nice pics there, thanks.
I took a better look today and tried the parking brake trick.
The parking brake trick did not seem to do anything, but i could tell that the normal rubbing sound might be caused by those drums and shoes because when i gently apply the parking brake while rolling, i can here the scraping sound get louder. That makes me think that sound is the brake adjustment.
However, the low rumbling is a different sound and happens mainly when i step on the brake, which makes me think it is something else causing that noise. I was wondering what if the shim was missing for the brake pads, and does every one of these brakes have a shim or just some models, and what is the shim actually do?
Has thanked: 2205 times
Been thanked: 1852 times
Is the rumble sound like it is from the front or back? It may not be a brake issue, but may be a wheel bearing starting to complain.
MrAl
Post by MrAl »
Hi,
Definitely passenger side back wheel.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
The rear rotors are like the ones in this video, main difference is the wheel studs are not part of the bearing.
rspi
Post by rspi »
This video may also help you.
MrAl
Post by MrAl »
Hi,
Thanks for the link. I'll check it out and see what i can find out.
Any idea what the 'shims' are for, or if they are in every model?
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
I may as well piggyback on this thread: If anyone know what is going on I would appreciate the enlightenment as it has my stumped:
View My Video
I have checked handbrake, and its not the handbrake. I thought rotor was not balanced perfectly, so I made sure it was concentrically mounted. The only thing I have left to do is replace the caliper with a new one. It seems to not be "opening up" I guess...
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
Just a quick note if you haven't ever done a rear brake job on these cars. The rotors will not just simply slide off like the front. You need to release the tension on the parking brake or else you risk tearing everything up. There is a small hole in the rotor to give you access.
Good Luck!!!!
mika
Post by mika »
^in my experience, once caliper is off, and the pin is off, the rotor just slides off. Maybe it is because my handbrake is not tight (I do not use it)
http://tinypic.com/r/ekozuw/8 if anyone has a free second, review my link, I am stumped!
'97 855 N/A
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
mika - pull the wheel off, does it still rub? If so, it is rubbing on the drum, probably inside from the shoes. If you want to be real thorough you can pull the shoes and put the drum back on, see if it still rubs.
I have seen the drum/rotor slide right off, or be deeply grooved and held captive by the shoes.
