Good point.misha wrote:If the problem is in pick up o-rings he should have oil light flickering at idle.Maybe a bit of both.
'97 854 Base Loud tapping from valve cover
- Has thanked: 311 times
- Been thanked: 817 times
- misha
- Has thanked: 155 times
- Been thanked: 432 times
No need for that since you allready changed it last week.Try with harder driving for 20-30 minutes in high rpm and see if the noise go away.Give those trapped horses a nice race.chrisn81 wrote:I'm just going to swap the oil out for 10W-40 on Thursday when I have some free time again. It's worth a few extra dollars to me to do the experiment. Thanks!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Hydro lifters.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
In that case, oil level and viscosity being good, you' ll have to replace lifters. They have this tiny ball valve that's supposed to hold oil inside the lifter and it soinds like it's not. Some recommend removing and soaking in solvent to loosen and clean inside deposits but I'd rather replace especially if mileage is high. Again, make sure noise is coming from top of engine. Did that for my VW ànd price was like 8 a piece for INA, but this being Volvo... Engine ran a lot different after.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
draser
Or, oil pressure is low(er) and top gets less than it should, or sludge partially covers oil ports.
- misha
He would have oil light flicker.draser wrote:Or, oil pressure is low(er) and top gets less than it should, or sludge partially covers oil ports.
If that is the problem,all of that should be more noticeable in colder weather or in cold engine because oil would be thicker than in hot weather and hot engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 57 Replies
- 27933 Views
Last post by shadetree_v70
- 988 Views
Last post by mdelaine
- 1061 Views
Last post by Clockboy
- 527 Views
Last post by Jdullwitted
- 1039 Views
Last post by kallekula
