1998 v70 Roof Racks, Recommendations ?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
No leak potential. The bolts go into, not through the roof.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
I just pulled my rails from the one in my avatar. They were on there from day one. A little tear on a couple of rubber pieces, but these things last forever. Six screws in the top, where anchors are already in place and some yellow clips to help keep everything flat. I think it changes the look of the Volvo in a good way.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- Has thanked: 311 times
- Been thanked: 817 times
I would agree that installing the factory rails is the way to go. Yes there are other crossbar products that fit without rails, but they are less common and therefore usually more costly. The factory rails work great and look good. With the rails you can easily take the cross bars on and off as needed.
Just to highlight: if you or anyone decides to go factory / junkyard OEM style rack: under your existing trim, there are pre drilled holes with threads for the bolts. The bolts for the rails are a security torx, so you will have to grind down middle with a dremel, or get the correct security torx bit.
Easy as Pie! This was the first "mod" I did on my v70, long before I started crawling under the car to do oil changes even
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
98v70dad wrote:Since someone suggested that installing the original Volvo rail opens up a lot of possibilities, how hard is it to install factory rails on a car that didn't originally have them. I would guess that there are attach points already there under the trim and its just a matter of removing the trim, bolting on the rails, and installing the new rails ... I'm guessing, though. Does anybody know?
right on the target. nothing else to it.
'97 855 N/A
'97 855 N/A
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi again,E Showell wrote:No leak potential. The bolts go into, not through the roof.
Oh that's very interesting. That would take some of the problem away then. Do you happen to know what size bolts they are, and how many are required to bolt the thing down correctly?
I ask because i'd like to get an idea how sturdy they are once mounted. Knowing the bolt diameter and length and number of bolts will tell me about this.
Thanks again
- E Showell
No idea, but I 'be carried multiple kayaks no problem.
'95 855 auto (sold)
'95 855 auto (sold)
obayha
Read previous post. I just took mine off my '98. It can carry a boat load of weight. No security torque on mine. I think it was a 25.
1998 V70 T5 331,000
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
FYI, if your only freaky cargo is that 2x4, you can carry that without a roof rack. The front passenger seat folds down (I didn't know this for the first two years I owned the car) and there should be plenty of space to get them in.
If you're not really looking into it for any reason besides hauling the occasional 8-foot plank, you're already covered. A roof rack is probably nice to have, though.
- MrAl
Hi again,
Thanks for the idea, i'll have to check into this. Maybe leave the roof racks for another time once i get the car running properly. I have some necessary mechanical things to do first before i can start adding the 'gravy' but the roof racks sound like a very nice addition at some point.
I am trying to learn as much as possible so that when the time comes i can jump in.
- 833 Views
Last post by jbkeene
- 2076 Views
Last post by Oly850
- 1129 Views
Last post by packetfire
- 1504 Views
Last post by 800artfreed
- 15 Replies
- 2123 Views
Last post by erikv11
