Thank you! That helps a lot. I've been looking for a copy of 2014 online.
I do not recommend purchasing from the user diagwork. It could all be chance, but the anti-virus picked up a "worm" on one computer, and several programs are no longer working on my main PC.
Pete
01 V70 Poor Throttle Response (ETM)
precopster
- Year and Model: Lots
- Been thanked: 128 times
I checked my Mega account. It seems I didn't manage to get it uploaded as it kept hanging. I'll try to get it up today.
precopster
Hang in there I'm still uploading at about 55kbps so it may take another 6 hours or more.
freedomfries
- Year and Model: Volvo
Not sure if this is the cause but I've read that NA engines are picky about plugs and run best on the OEM 3 prong plugs. Might be worth a try since they're only $25-30 for a set of 5Daspete wrote:Spark plugs were replaced as soon as I got the car. There were autolites in it before. I put in single prong Volvo plugs. I'm not sure which ones exactly, and I did not gap them. I have not done the coils. It is not misfiring.
precopster
And here it is:
Vida 2014A and is a tested version
https://mega.co.nz/#F!wpxjCazI!-sLkWCh3LgyCrfOHQT49JQ
Use Chrome or Mozilla because some versions of IE don't support Mega's site
The files have been modified to allow a lower level of system RAM so anything over 1.3GB is OK using this install. Each folder or file can be individually downloaded as a zip file by using the right click menu.
precopster
I thought you would succeed with the install if you stuck with the download. It's a lot faster than the virtual download alao here on.MVS due to smaller size.
I got the software up and running. There was a problem with .netframework, I had version 4.5.2 and had to downgrade to 4.0.0 to get the DICE setup to communicate.
Probably going to sell the v70, it has alot alot of mostly electrical problems.
I just got a '95 850 wagon with 110k on it.
Thanks for the help! The software is pretty cool, I still haven't figured it out all the way. I did get to run some diagnostics though!
precopster
What kind of electrical problems do you have? Are they faulty modules or random unexplained stuf ?
With Vida you can work through all of them without visiting the dealer. Vida can't access downloads however there is a forum member who can use the Dice as a passthrough and update or reload 99% of the software you may need.
- 14 Replies
- 5079 Views
Last post by mrbrian200
- 3050 Views
- 655 Views
Last post by ignatz
- 923 Views
Last post by oragex
- 3756 Views
Last post by rspi
