'06 V70 NA throttle response
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
I recently replaced timing belt, upper/ lower torque mounts and right side lower mount. I did all the work at the same time. I noticed a significantly better throttle response at all rpm ranges. Is this because all of above parts being replaced. Does timing belt stretch enough over time, that performance improves when installing a new one or am I just experiencing the placebo effect. Just wondering. Thanks Glenn
- Been thanked: 4063 times
You may have jumped a tooth on time? you get about three teeth before damage so most will only notice it off the line.
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
These old Volvo's just "know" when you've been in there 'investing' in them. Get the job right & they tend to reward you, as you noticed, occasionally
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The belt does not stretch, but as above, might have been a timing issue
- 21 Replies
- 5272 Views
Last post by precopster
- 655 Views
Last post by ignatz
- 14 Replies
- 5078 Views
Last post by mrbrian200
- 3756 Views
Last post by rspi
- 2987 Views
Last post by Fosgate
