- There's no correlation between your turbo and your transmission.
Just forget about that.
- Unless you put it on yourself, or a previous owner did, your car does NOT have a BOV.
Such a thing, in any case, would not be on the turbo, but on a hose with a customization for such a contraption. Now, instead, we've got wastegates and a "resirculation" system of sorts on these cars.
So, forget about BOVs, and forget about transmissions.
Here's what you should probably do, given that the techs told you you had a vacuum leak:
Tools you'll need: A good flashlight.
I ususally bring both my SureFire and my LED work-light when I go hunting in dark corners of the engine.
1: Find out where you turbo is, and take a good look at it.
There should be a few hoses, but 3 smaller vacuum hoses "on top" are the ones you're possibly having issues with. They're small (5 mm -ish), they're black, and if they haven't been changed, they're color coded with little bands. 3 of them.
2: Follow them to the TCV. Now you know where that is.
3: Check all those small, rubber or silicone hoses for leaks.
Then, when you've done that, check all your air hoses for leaks. Follow the metal pipe from the top of the turbo that goes over the engine, and check the rubber hoses you encounter for leaks. There should be 5, all in all, counting in the little "coupler" on top of the turbo, just between the turbo and the metal tube over the engine.
Don't worry about going underneath the car - you probably won't find a vacuum leak from under there.
4: Take pictures, and post them here if you want and if you get stuck, and someone will help you.
- S
