1999 S70 NA PCV system fix caused misfire
kyalami321
Year and Model: 1999 S70
Post by kyalami321 »
misha wrote:You fried ignition coils and who knows what else. :!:
I told you that you messed something up.
How embarassing :? Ok so other than scrapping the project, and besides replacing the 02 sensor, how can I diagnose the mess I've made? I have a fancy multimeter I could use to diagnose.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Replace coils first,then intake gasket,install etm properly.....fix everything.
Bad o2 sensor is not the reason of your symptoms or problems.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1613 times
Been thanked: 4077 times
Nope. The zzzzt was when you were reconnecting the starter wires and you shorted them to the block. That's really dangerous by the way. The current can weld your wrench to the metal tand then discharge your entire 1kW battery charge in a few seconds
Have a good luck at your wiring looms under the manifold to make sure you didn't damage them
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Well... The car starts and runs, so the damage can't have been too extensive in the electricals...can it? I hate electricals - it's the only thing which never seems to make sense to me, at least.
Anyway - just to rule out the absolutely most basic thing that could cause your troubles... You're sure that you put coils and plug wires back in the right order...?
- S
[Sold] '97 S70 T5
The coils need to be tightly screwed down as the 10 mm bolt is the ground point. With the original wiring harness I don't think you can mess up the coil plugs but the looms often self destruct on older cars, so it's worth checking , especially cylinders 4 and 5
kyalami321
abscate wrote:The coils need to be tightly screwed down as the 10 mm bolt is the ground point. With the original wiring harness I don't think you can mess up the coil plugs but the looms often self destruct on older cars, so it's worth checking , especially cylinders 4 and 5
To what do the looms on the coils connect to? I see that they lead somewhere to the right underside of the engine block ... also, with a multimeter, what's the best way to diagnose whether the coils that don't work are getting power?
Scour threads for 1999 v70 t5 coil measurement where yours truly measured and assigned pins ( I think)
The coils get 12 VDC with the key on, all the time and are fired by the ECU by grounding on command
You need an oscilloscope to diagnose these other than confirming supply voltage and ground
I have cross referenced most of my DIY threads in my maintenance log ( public) for my 1999 V70 T5 Nautical Blue thread
linked here, plus I bumped it by adding pinouts.
https://www.matthewsvolvosite.com/forums ... 45#p375145
kyalami321
abscate wrote:Scour threads for 1999 v70 t5 coil measurement where yours truly measured and assigned pins ( I think)
OK, so I tried two new coils from another S70 and no dice. Coils aren't the problem.
On both one "good" cylinder and one "bad" cylinder, I get the following.
PIN 1 = 0 VDC
PIN 2= about 5 VDC
PIN 3 = 0 VDC
PIN 4 = about 12 VDC
What's my next step? Pin 2 should be ground, meaning 0 volts, right? Are malfunctioning fuel injectors for those 2 bad cylinders a possibility?
Thanks so much to everyone for your help thus far.
misha
Post by misha »
Since you had "sparkling" adventure in process of pcv replacement,i would not be surprised if you burnt ecu or at least some relays.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
kyalami321
I'm gonna check the 12V green wire on the injectors as well as the relays that are to the left of the cooling fan. Maybe those are causing the problem.
