oh, just one more. Blue Devil "Oil Stop Leak" greatly increases the engine's oil pressure. [i actually used smaller version of what i (only) assume is just the same 'formula', 'blue devil rear main sealer'.] Although i can see no harm in this, [and have had no problems], i think it may have gone up at least 25%! This is based on a 'sense' of what my oil gauge used to read, as it fluctuates around. But i never really took note of what it used to be...
From this experience, i surely recommend using 'high mileage' motor oils as a preventative to just this kind of a problem! Remember, the Blue Devil 'oil stop leak' stuff basically is this the same type of chemical [as 'high mileage oil], -only on mega-steroids! But the seal might well have been 'gently' expanded changing the oil with 'high mileage', and this never happened. Not sure, but seems cheap enough insurance!
01 v70 xc Timing belt and cam seals replacement. big leak
Wow, did i say 'one more'? I forgot to mention that the 'cog' through which i was able to reach my 'popped out' seal wasn't a vvvt cog, as i do imagine both the cam cogs are in the car this thread was about. Whoops. I'm in the wrong forum! My car [2000 s70 glt se] actually has the vvvt cam for the exhaust, but my intake cam is the non-vvvt, thus the 'classic' cog model, with the big hole spaces. I believe that previous to about a 1998 s70/ v70/ c70 there were no vvvt's. I don't know if what i did would at all be possible with the vvvt timing belt pulley, or 'cog'. But since vvvt cogs have no holes in the pulleys, you can't reach through them with a stubby screwdriver to push the cam seal back in. As i said, had i had to 'do this right', i'd have probably junked the car, and if my rearward exhaust cam seal would have popped out, i would have had to, as i believe that you need a cam locking tool to deal with the vvvt cam pulley removal, [not dead sure on that]. So this little desperate fix will only be for non vvvt cam seals! I can't rule out some kind of hooking tool to 'work around' the vvvt pulley from the back. But no, I really don't think so...
- 36 Replies
- 21217 Views
Last post by Achilles
- 2169 Views
Last post by chrism
- 38 Replies
- 16143 Views
- 12 Replies
- 4984 Views
Last post by ashgoldS60
- 2615 Views
Last post by tpdtopcop
