Found my 99 Original radiator
I only have the auto trans oil cooler on mine but the cooler is sealed with two thin rubber washers inset into both the cooler and the fittings.
Volvo OEM Radiator Dissected
- June
- Has thanked: 523 times
- Been thanked: 261 times
If the 99 radiator is bad can you open it to see what type cooler and the interior looks like on a 99 era Volvo from the factory? Juneabscate wrote: 02 Dec 2017, 11:47 Found my 99 Original radiator
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
This looks fairly typical of most OE rads since around 1985 or so. They're designed to last about 100k miles, at which point they begin springing leaks around that crimp to the plastic end caps. Higher quality replacements that would hold up for the remaining life of a car are harder to find for Volvos. Probably because sales volume is lower the smaller operations that specialize in high quality durable rads aren't as likely to venture into our territory.
It's kind of sad in that the coolant type used by Volvo does seem suitable to be paired with higher build quality/lifetime rads as evidenced by the lack of corrosion or deposits on that one. However in salt zones exterior corrosion would likely do them in anyway.
- June
So do I understand you to say the lack of deposits means Volvo coolant is bad? I thought no deposit forming is desired. Junemrbrian200 wrote: 02 Dec 2017, 14:06 This looks fairly typical of most OE rads since around 1985 or so. They're designed to last about 100k miles, at which point they begin springing leaks around that crimp to the plastic end caps. Higher quality replacements that would hold up for the remaining life of a car are harder to find for Volvos. Probably because sales volume is lower the smaller operations that specialize in high quality durable rads aren't as likely to venture into our territory.
My Volvo cars owned
1996 960 ordered
1996 960 ordered
June wrote: 02 Dec 2017, 13:01If the 99 radiator is bad can you open it to see what type cooler and the interior looks like on a 99 era Volvo from the factory? Juneabscate wrote: 02 Dec 2017, 11:47 Found my 99 Original radiator
Sorry, I trumped on that one
It's actually my first replacement Nissens from 2013
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I think he is trying to say that the Volvo coolant is so great at preventing corrosion that it deserves to be paired with a high quality all aluminum radiator like the do88 for what is essentially a lifetime setup.June wrote: 02 Dec 2017, 14:51So do I understand you to say the lack of deposits means Volvo coolant is bad? I thought no deposit forming is desired. Junemrbrian200 wrote: 02 Dec 2017, 14:06 This looks fairly typical of most OE rads since around 1985 or so. They're designed to last about 100k miles, at which point they begin springing leaks around that crimp to the plastic end caps. Higher quality replacements that would hold up for the remaining life of a car are harder to find for Volvos. Probably because sales volume is lower the smaller operations that specialize in high quality durable rads aren't as likely to venture into our territory.
- mrbrian200
'Volvo coolant is so great at preventing corrosion that it deserves to be paired with a high quality radiator' is what I meant, yes. I re-read my post. To clarify. It's sad that Volvo didn't use a better radiator. It's good that the fluid resists corrosion and deposits so well.
I have a habit of combining several ideas into long compound sentences. Sometimes it works. Other times it just confuses the hell out of anyone trying to read it.
- 1778 Views
Last post by ThommyKent
- 15 Replies
- 2549 Views
- 3557 Views
Last post by t3yf5g
- 7135 Views
Last post by jalwlb
- 108 Views
Last post by volvolugnut
