2004 Volvo S40 Cranks but Won't Start
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
richardmills2 wrote:...2 of the codes were 2 different cylinders misfiring. It just so happened that both cylinders are on the same coil...
What engine do you have on the car; I thought your S40 should have a 5-cyl., no?
If yes, then you have coil-over-plugs, one for each cylinder. It is (almost) impossible to mistakenly swap the electrical connectors between coils, and therefore your sparks should be timed correctly.
Once spark and correct timing are verified, I would check if the injectors are 'firing' at all. If they aren't, the 12V DC common power supply could be missing; if it is there, then it is the CPS
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Clockboy
Year and Model: 05 xc70, v70 2.5t 06
Post by Clockboy »
Did you ever do a simple compression test? What did the spark plugs look like? Was there any gas or oil on them? Was the car started cold and then stopped right away right before it would not start again? Still would check the fuel injectors.
