'95 T-5R Awful Clunking Suspension
- Has thanked: 2203 times
+1 to what Russ says on the anti-sway bar end links. They don't tend to fail at the same time.
Euro_Hobbs
- Year and Model: 1995 850 T-5R
Call from the shop, they said they hear the noise but cannot determine where it is coming from...said the sway bar bushings (not links) look fine as so the links (i'll tighten them myself). They have a theory it's the castle nut on top of the strut not being tightened enough but couldn't tell me without charging for strut disassembly.
Current Car:
Cream Yellow 850 T-5R w/230k and counting!
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
If the latter is true, wouldn't you be able to see movement relative to the inner fender tower and the threaded shaft of the strut when you bounce that side of the car?
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
dosbricks wrote:If the latter is true, wouldn't you be able to see movement relative to the inner fender tower and the threaded shaft of the strut when you bounce that side of the car?
Yes, you would...clearly
Remove the hex nut, large washer and check for yourself. If it is indeed loose, tighten it!
'00 S70, '04 S60 and the never ending quest for Stage Zero
- 2761 Views
Last post by DavidE7
- 25 Replies
- 1714 Views
Last post by dikidera
- 16 Replies
- 2405 Views
- 608 Views
Last post by tjmartin317
- 762 Views
Last post by ItWasTheSalmonMoose
