Will also check once more on this one. Thanks.ferocity02 wrote:My IAC makes a similar noise. Doesn't sound good but it works.
I'm thinking a vacuum leak. Since you just did the PCV job maybe a vacuum line came off.
1998 V70 T5 2,3l Very high idle at start
- Been thanked: 504 times
In most modern gasoline engine (post-carburetor era...):
- A vacuum leak usually causes misfires and stalling (lean mixture).
- When the engine revs up higher than normal, this happens because:
* stuck throttle plate
* bad ECT sending wrong signal ---> ECU sens out wrong output for injector.
- 630 Views
Last post by MrAl
- 1892 Views
Last post by 93Regina
- 953 Views
Last post by sweedespeed1
- 398 Views
- 13 Replies
- 2841 Views
Last post by Rattnalle
